RV-8 N605TT
Date:  2-29-2008
Brief Description:  tail wheel mount
installed tailwheel spring (tailwheel extension) to tail wheel mount. i had previously inserted the spring but had aligned the pilot holes to match drill. today i used the laser level and levels to level out the fuselage. next was multiple adjustments to ensure the wheel mount was vertical. then the mounting bolt hole was drilled.
i'll still have to paint the assembly but it is now final drilled.
