RV-8 N605TT
Date:  2-24-2008
Number of Hours:  3.00
Brief Description:  rudder pedal assembly
layed out & studied rudder pedal assembly. made F8115 thrust washers. i am using the ground adjustable rudder pedals which save weight and some complexity vs the in-flight adjustable design. Van's recommends have an extra set of f852 rudder cable links on hand in the event that adjustment is necessary. this is because the links are actually trimmed to fit specifically to the rudder pedal setting.
