rolled the control surfaces leading edges. this turned out to be a much more difficult process than i had imagined. the technique offered in the manual sounds easy enough, but i found it to be a difficult task to achieve good results. luckily, these leading edges are hidden behing the HS & VS skin overhang. the edges are a bit wavy and the pop rivets just aren't pretty.
