RV-8 N605TT
RV-8
installed trim tab & cleanup shop
installed trim tab with temporary hinge pin. permanent hinge pin of correct length is supplied with fuselage kit. moved trim tab through full range to check for binds. no problems evident.
RV-8 Home
1374
Avionics/Electrical
179
Finish
465
Gear and brakes
Hangar/Workshop
Inspection
Inspections
Pre-Build
Workshop
