Worked on the elevator skin stiffeners. These are done exactly like the rudder stiffeners (ref 9/17/06). They're cut from aluminum angle and then tapered to fit inside the folded trailing edge skins. I cut the rudder stiffeners in the band saw, but did these with snips. I actually liked the results with the snips.
Also match drilled the right elevator top stiffeners.
