RV-8 N605TT
Date:  5-11-2013
Brief Description:  Brake fluid reservoirs
Installed individual brake fluid reservoirs directly to the master cylinders. This differs from the plans specified method of running nylon supply lines to a single reservoir on the firewall. The method I choose elimnates two firewall pass-thrus and simplifies plumbing by eliminating the low pressure supply lines. The reservoirs are the commonly used ACS-600 reservoirs from Aircraft Spruce.
