Johns Web Site
Date:  3-30-2017
Number of Hours:  6.00
Brief Description:  Small Details Cleanup
Today, the following was completed:
The EFIS software was updated to version 13
The EFIS database was updated
The trim cable clamp was mounted on the left map pocket
The wiring through the fuselage was dressed into the wire channels in the fuselage sides and covered
The engine mount bolts at the firewall were torqued to 260 in/lb
The carburetor heat cable was adjusted and safetied at the firewall pass through
The throttle, mixture, and carburetor heat cables were safety wired to their cable clamps at the carburetor
The carb and cabin heat controls were labeled in the cockpit
The rear half of the aft lower skin was riveted.
