(Continued from the previous post) The layup was completed using West System 105 Epoxy Resin. All four layers were thoroughly wet out, then covered with a sheet of peel ply to provide a more uniform surface for easier finishing.
To ensure that the four layers were evenly compacted and in good contact with the cowl, the layup was covered with a clear plastic sheet, then a 2.5 gallon hefty bag was filled with about one gallon of water, and placed over the layup to apply uniform pressure until the epoxy sets up. This will cure until tomorrow morning.
