Over the last three days, I have continued with the trimming and trial fitting of the upper cowl. It is a process of many iterations. After sanding to create clearance in one area, another area tightens up and must be sanded. This process continues with diminishing amounts removed, until everything settles into place.
Three layers of fiberglass were laid up on the underside of the upper cowling to raise it up to flush with the upper boot cowl skin.
Some minor filling with epoxy flox was applied in a few areas. The epoxy will cure overnight, and I’ll see what additional work is needed in the morning.
