Johns Web Site
Date:  2-11-2016
Number of Hours:  6.00
Brief Description:  Initail Canopy Frame Fabrication and Assembly
While waiting for wingtip pinhole filler and primer to cure, work was started on the canopy side rails.
The first task was to cut the two slots in the hinge side rail for emergency hinge pin extraction. Since I have a table top milling machine, it was an easy matter to cut both slots. Several holes were then marked and drilled in the side rails and some of the small components bolted in place.
Milling 3/16
Milling 3/16" Slots On Hinge Rail
Completed Slot
Completed Slot
Rail Assembly Underway
