Johns Web Site
Date:  10-17-2016
Number of Hours:  4.50
Brief Description:  Drain Valve
I decided to add a Curtis drain valve at the lowest point in the fuel system, for preflight sampling, and as a single point fuel system drain. The idea was to replace the standard bulkhead fitting with one that included a Tee for the drain. However, I could not find an AN fitting configured as I needed, so I purchased a steel AN804-6 Flared Tube Tee With Bulkhead On Run fitting.
Since they don’t make Curtis drain valves with 37-degree female fittings, I shortened the bulkhead Tee leg, and drilled and tapped it with a 1/8-27 NPT tap. The Curtis drain valve was tightened in place with a sealant and the fuel lines on both ends were restored. The valve hangs about 3/8” below the firewall, and is easily accessible through the opening in the lower cowl.
I received the remaining anchor nuts needed to complete the cowl mounting system, and they were riveted in place today.
View From the Front
View From the Front
View From the Bottom Right
