Today, work on the avionics wiring continued. The transceiver wiring was completed except for the antenna BNC connection. The control stick wiring for the PTT, frequency flip-flop, and AP engage, were also completed.
All of the related circuits were double checked with an ohm meter. Found that one resistor that was not properly clamped in its barrier strip. Fixed it and confirmed that the wiring conformed to my wiring schematic. Sure hope I generated the schematic correctly.
Avionics Shelf Wiring From the Left Side
From the Front
Top View of the Stick Connections & Passive Audio Mix Network
