Brief Description: OAT, Static & Pitot, Wing to Fuselage Connector
The wing side of the OAT, Static & Pitot Connector was assembled today and mounted to the left inboard rib temporarily. The fuselage block without the electrical contacts was temporarily mounted to the fuselage with clecos from the inside of the fuselage.
The wing was pushed into position to see if the two components were correctly aligned, and it mated up without difficulty. The wing was then pulled out, and the connectors decoupled without issue. Need to finish the permanent mounting of both ends.
