Brief Description: Throttle, Mixture, Carb Heat, and Cabin Heat Contr
A bracket for the cabin heat control cable was fabricated from angle aluminum, clecoed to the right cabin skin, and the cable mounted. I decided to keep this control separated from the engine controls, to keep from confusing my geriatric brain. The cabin heat valve will be rotated 180-degrees on the firewall for proper actuation from the right side, and be fed from a heat muff on the right exhaust manifold.
Throttle, Mixture, and Carb Heat Cable Mounting Bracket
