Brief Description: Updrilling the Forward Vertical Spar
With the stabilizer assemble on a work bench and sitting on a couple of 2X4s to provide room to work from the bottom, the forward horizontal stabilizer brackets were updrilled and reamed for close tolerance bolts. Temporary hardware was installed to lock them in position.
The vertical stabilizer front spar was then updrilled and reamed to the horizontal stabilizer spar, and locked in position with temporary hardware.
