Today the foam/carpet panels were glued to the left interior skin.
With all of the foam/carpet blocks now permanently mounted, the sides were clecoed in position, the map and phone pockets, headset panel, and push-pull controls were mounted to check for any interferences and appearance. A couple of minor adjustments were made, and it all looks good.
The cabin heat cable was cut and connected to the cabin heat valve.
