Brief Description: Brake Master Cylinders and Rudder Pedals
I received the forward fuselage hardware yesterday, and after taking inventory last evening, I fabricated the master cylinder extension tubes. The tubes were cut a little oversize, then the ends were cleaned up and the lower end tapped on my lathe.
The rudder pedal assemblies and master cylinder assemblies were mounted in the fuselage, and the lower end of the master cylinders were connected to the rudder pedals. I am not sure that I have the correct spacer between the master cylinder and rudder pedal, but I’ll figure it out.
