Brief Description: Adding Bits & Pieces to the Forward Fuselage
Today, the engine mount holes through the firewall were enlarged slightly to allow the engine mount bolts to pass through without interference.
I also trimmed, match drilled and clecoed the cheek mount angles, the cheek formers, and the joggle strips under the side skins on both sides.
The left exhaust tunnel former, tunnel fairing, and front tunnel former were trimmed and clecoed in place, then the fairing was match drilled under the left forward skin.
