Brief Description: Marrying the Forward and Aft Fuselage Assemblies
Today I rechecked the alignment between the forward and aft fuselage assemblies, and made a very minor adjustment in the elevation of the aft end at the tail wheel spring. After clamping the upper joints (images #1 & #3,) the lower joints were match drilled through the pre-drilled holes (image #2,) one on each side and two on the bottom. Clecos were installed in these holes to lock them in place, then the upper joints were match drilled through the pre-drilled holes, and clecoed.
