Today, I removed the left aileron bellcrank from the wing, attached the short aileron push rod, then remounted the bellcrank. The left aileron was mounted to the wing and the other end of the short push rod was connected temporarily to the aileron.
I started the completion work on the right aileron. The rivet holes were up-drilled and deburred, and the holes for countersunk rivets were dimpled.
