Stripped the protective film from the upper left, inner and outer wing skins. Carefully aligned, drilled, and clecoed, the upper skins to the ribs and spars.
Before starting the drilling, the location of the holes near the front spar stiffeners was checked to be sure they did not interfere with the stiffeners as cautioned in the Builder’s Manual. Turned out perfectly.
