Removed the protective plastic from the inside of the skins and ribs. Used a pencil soldering iron to cut the protective plastic along the rivet lines on the outer skin surfaces, then removed the resulting narrow strips of plastic along the rivet lines.
Marked the centerline of the ribs and started a trial assembly of the spars and ribs.
Photo files were inadvertently lost during transfer to my computer.
