Some of the vinyl graphics were applied to the plane today, including the N numbers, carburetor heat caution, Experimental graphic, and baggage weight limit graphic.
A clamp was applied to the static line at its entry point into the fuselage, and a safety wire was added to the trim cable at the rear of the fuselage.
