Johns Web Site
Date:  12-13-2016
Number of Hours:  4.00
Brief Description:  Aileron Balance +
The right aileron was removed from the wing and mounted to the bench with short hinge halves screwed to the bench top. With an iterative process, holes were drilled in the rear of the lead mass until the top surface of the aileron was level. This will leave the ailerons slightly over-balanced until the paint is applied.
Right Flap Attached to the Bench
End View
End View
Drilling to Reduce Mass
