Brief Description: Air Speed Indicator Mount and Wiring
The bolt hole pattern on my backup airspeed indicator is too close to the instrument body to use standard nuts; so I designed and fabricated an aluminum plate-nut. It worked out very well, and the ASI is temporarily mounted. It and everything else in the IP will be removed after I finalize and receive the Vinyl graphic for the panel.
