Today the cutting of fuselage wireways was completed. The two wireways that cross the wing spar box structure are fabricated from 1” square aluminum tube. Both of these also support the forward end of the rudder cable covering tubes, replacing the aluminum tube spacer specified in the BM.
The remaining wire ways are cut from plastic extrusions from Lowes, normally used to hide otherwise exposed cords associated with home entertainment systems.
All of the wireways are painted gray to obscure them as much as possible.
I also completed measurements to determine how much coax cable to order. Measured out to 22-feet.
