Brief Description: Starter and Engine Ground Wiring
Most of the wiring supplies have been received, so I started work on the wiring. The 4 gage wire from the master solenoid to the solenoid on the starter was terminated on the starter end, and passed through the rear baffle and temporary firewall. The master solenoid end will not be terminated until the plane is moved out of the basement workshop to the hangar.
The 10 gage starter control wire was installed and terminated on both ends.
The 4 gage ground wire from the engine to the firewall was terminated and installed.
