Brief Description: Fabrication of the Carb Heat Box
The fabrication of the carburetor heat box was completed today. After these photos were taken, the control arm was shortened by one hole to eliminate interference with the engine mount.
The control arm is welded to the one of the two 3/16” shaft collars.
Photo #3 shows the access hole in the bottom, to provide access to the nuts that mount this box to the carburetor.
