Brief Description: Stick & Elevator Control System
Today, the forward and rear bearing/mounting block units and the BC4W10 bearings were mounted to the control stick box – one side was riveted and the other clecoed so rigging adjustments could be made easier.
The holes at the forward end of the elevator forward control tube were reamed to clear the powder coating. One MW5 rod end was bushed to 3/16 ID and another was bushed to ¼”, then both were fit unto the ends of the elevator forward control tube.
