Cleaned and painted two push rod tubes recently received from Clark's Corvair Parts. They were supposed to be in "perfect condition." There is a vast difference between their definition of perfect and mine. They were useable however, so I will use them.
I also bought an oil fill cap from Clark’s that was supposed to have only light white corrosion. It had heavy white corrosion, but after tearing it apart, cleaning, priming, and painting, it will work.
I cut five inches off the oil dipstick tube, then cleaned it up with scotch bright; and after painting, it looked good.
I received eight valve cover clamps from Clark’s; five were useable after cleaning. The other three are so deeply rusted that I consider them unusable. I will order five more and maybe I’ll get three more good ones. Fortunately they are not expensive.
