Brief Description: Fuselage Teardown For Final Marriage
Today I removed the vertical and horizontal stabilizers, and with the help of a neighbor (also a repeat homebuilt aircraft builder) flipped the fuselage on it side to provide access to the bottom surface.
The holes for the bottom surface splice bolts, three on each side, were marked drilled and reamed.
