Johns Web Site
Date: 5-6-2015
Number of Hours: 5.50
Brief Description: Initial Aft Fuselage Assembly
While waiting for the new “Tank Dimpling Dies” for blind, closed end rivets to arrive, I decided to begin assembly of the rear fuselage.
A slight bend was applied to the forward edges of the left, right, and bottom, rear fuselage skins with my Harbor Freight brake. This provides a nice blend between the forward and aft fuselage assemblies.
The four longerons were match drilled to the left and right aft skins with a #40 drill. Unfortunately, the drill bit broke and left an ugly scar in the skin. I guess that’s why God invented body filler.
Bulkhead #1 was clecoed together, and after several passes at getting everything oriented correctly, it and bulkheads 3, 4, and 5 were clecoed to the right side of the aft fuselage assembly.
Everything fits together very well.
Match Drilling the Longerons to the Skin
Adding the Seven Degree Bend to the Forward Edge of One of the Side Skins
Bulkheads 1, 3, 4, and 5 Clecoed to the Right Aft Fuselage Skin/Longerons.
