Pilot (#40) drilling of the Upper and lower right wing skins was completed today without any problems.
The leading edge skin was then positioned on the right wing, and the rear edges were temporarily slipped under the forward edges of the upper and lower skins for drilling purposes. The leading edge skin was clecoed to the matched hole ribs, using a scribe to maneuver the skin and rib holes into alignment. Everything matched up well with a good tight fit of the skin around the rib leading edges. The aft edge of the leading edge skin was match drilled to the spar by transfer drilling though the previously drilled upper and lower skins.
