Jim Helicopter Web site
Date:  10-16-2005
Number of Hours:  9.50
Brief Description:  Finalize fuel system mount tube installation
Setup and test fit the fuel system mount tube and brackets to make sure there was proper clearance between the fuel tube and the engine mount weldment. Leveled left to right and then removed the engine mount weldment to allow drilling of the fuel system mount tube brackets. Drilled each and then centered the fuel system mount tube L&R and bolted in-place. After all was checked for correctness, I removed all and stamped my serial number to make ready for primer and paint next week. Helped Ron and Spenser perform the same work and helped Don setup his tail boom.
Pilot side fuel system mount tube bracket ready for drilling
Right side fuel system mount tube bracket and new battery box leveled and ready to be welded in-place.
Fuel system mount tube in-place
