JOHN'S WEB SITE
Date:  7-2-2011
Number of Hours:  4.00
Brief Description:  VS Final Riveting
Completed Rivet Assembly of the Vertical Stabilizer. It was quite similar to the HS, but much easier since I already climbed the learning curve on the HS. I think the quality of the VS is a little bit better than the HS -- not a big difference, but I'm getting better. For instance, my skin dimples are a bit cleaner because I applied a little more pressure using negative clearance on my DRDT-2 and I didn't use negative clearance with the HS skin. So, the HS skin dimples could have probably used a little more pressure for "tighter" dimples.
Starboard Side
Starboard Side
Port Side
Port Side
Aft Side - Stiffener, Rear Spar & Rudder Hinges
