Since I shall have the rear stick disable switch on one of the center bulkheads between the seats on the right side of the cockpit, it follows that there will also be a certain amount of wiring in that location as well. I wanted to ensure this was protected so I fabricated a cover from .025". The tricky part was getting the holes to match the existing holes in the bulkheads, but I managed this by fabricating a 'strap-duplicator' with a #8 screw at the end for location. I crimped the edges to provide a little extra stiffness but later decided it really needed a stiffening angle. I also notched the floor panel to allow the rear stick grip wire bundle to come up behind the new cover panel.
