Just did a couple of minor outstanding tasks today. Installed nutplates on the aft baggage shelf. Fitted the aft baggage bulkhead and drilled the F-808 bulkhead for nutplates. Installed nutplates. Found that the rivets holding the little brackets on the aft baggage bulkhead interfered with the F-808 bulkhead flange, so filed a couple of little slots in the flange.
Test fitted the fwd canopy frame to the fuselage. Found it didn't fit. The 3/16" holes that should match with the cockpit rail were a complete hole too high. Bent the frame as necessary to match the fuselage. Clamped the frame into the correct position. Will match drill some other night.
