Edge-finished the seat floors and the aft baggage floor and shelf and cleco'd in place into the fuselage. I had to relieve the forward outside corners of the floors a little to get them past the bulkhead brackets but once in they were fine. The other thing I had to do was widen the slot in the left floor panel for the rear seat crotch belt brackets. Since we are using the Hooker harness which has a wider attachment, we put an S-bend into the attach brackets to accomodate them. Thus we had to also widen the slot to get the floor panel to go over the wider brackets.
