Fitted the forward bottom skins (F-850 and F-851-L/R). They aren't match drilled yet. As you can see, since I am using Grove gear legs, which use larger mounting brackets, I have had to trim the skins slightly to fit around the outboard fwd and aft ends of the bracket.
