Finished drilling all the #40 holes in the F-824 aft fuselage side skins. Unfortunately, when I put the fuselage on saw horses I also put a piece of ply between the front two horses to create a platform for it to sit on. To make sure the wood stayed put I screwed it down. Of course, now I need to drill the center section from underneath, but I can't because the ply sheet is in the way. Screwed down. And I can't get to the screws. And the fuselage is too heavy for just myself and Jackie to lift. And my sister's man, two doors away is working late! So I'm stuck until he gets home in a couple of hours. No more work tonight then...
