Jeff & Jackie's RV-8 Project
Date:  1-1-2007
Number of Hours:  1.50
Manual Reference:  7-12
Brief Description:  Left wing tip
Finished installing all the skin attach nutplates, and the light mounting nutplates. I installed the tip rib, but on one of the forward rivets there was some cracking around the rivet. It felt like a little more than just the gel coat and there was a little too much movement for my liking, so I've reinforced the area with some additional layers, just in case. Of course, as soon as I did this I realised that what I *should* have done is work on the lens first, then do the glass work last thing tonight; I've just wasted a whole day wiating for this to set. Bugger.
Reinforcing around the tip rib
