Jeff & Jackie's RV-8 Project
Date: 12-10-2006
Number of Hours: 1.25
Manual Reference: n/a
Brief Description: Priming
I know half the picture is in shadow (sorry), and yes, I should have been skydiving on a day liketoday instead of playing with the wing tip, but here is the right tip rib, right flap hinge, and rightW-816 aileron pushrod being primered (also primered the flap brace). To hol dthe pushrod, I just put a couple of long screws through some blocks of wood and clamped the wood to the priming table. The rod was help between the two screws and could be rotated as necessary. Easy! Once the burraway arrives from Wicks, and the nutplates/screws from Aircraft Spruce, I'll be able to carry on with fitting the flap hinge & flap, and doing all the nutplates on the right wing tip.
Priming the right wing tip rib, W-816 pushrod and flap hinge
