Jeff & Jackie's RV-8 Project
Date:  10-14-2006
Manual Reference:  7-11
Brief Description:  Left flap - spacers
This is an example of how not doing something at the right time can cost a lot of extra time later on. I did (or didn't do) two things that cost me a lot of extra time. The first thing I didn't do was drill the holes holding the flanges of the ribs to the spars to #30 for the correct size rivets. The second thing I didn't do was the spacers between the end ribs and the top skin under the flap where the two skins overlap (not that the RV-8 instructions or plans mention it anywhere; I got this from Phil's RV-7 flap drawing). Of course, I had taken the skins over to Phil's today to dimple them, so I could just re-assemble everything and drill. No, I had to first deburr and dimple all the ribs, finish dimpling the skins around the edges and also dimple and countersink the front spar!! As a result, what should have been a simple couple of jobs took me two hours!! At least it is done now. I have just the three bottom holes on the top skin to dimple when I disassemble again, and then everything can be edge-finished and primered. Before that though, I'll be needing to make the various brackets for the inboard end.
Countersinking the front spar
Drilling the spacer
Drilling the spacer
...and here it is!!
...and here it is!!
