Jeff & Jackie's RV-8 Project
Date:  7-4-2006
Number of Hours:  0.50
Manual Reference:  7-2
Brief Description:  Organizing rear/main spar assembly
Spent half an hour or so cleco-ing the various bits and pieces together and sorting out rivets, nutplates, nyloc nuts, washers, bolts, etc. We'll start the assembly process tomorrow evening; neither one of us feels like it tonight. Jackie will continue with edge finishing the main ribs while I do all the spar assembly work. I also need to drill the holes in the main ribs for the wiring conduit, and also work out what I need in the way of tubing/wiring runs for the Angle-of-Attack Pro that is being installed in this wing. When that's all done, we can assemble the wing skeleton on the bench.
