Took me an hour to edge finish that damn flap brace with all those holes in it!! Now, when Jackie and I order pizza, we also get these little boysenberry cheesecakes and chocolate mousses. They're quite nice. I have the cheesecake and Jackie has the mousse. The little plastic tubs are really handy in the shop for storing little bits and pieces, so we wash them and keep them. Since I only wanted to mix a small amount of primer I did it in one of those tubs; just the right size! Except, as I found out half an hour later after I had let the mix flash off, PPG DP40 primer doesn't like those tubs as much as I do. I went to pick it up to pour into the gun and the bottom fell out!! Yep, bit of a mess that! Just as well it was only a 'small' amount; covers well though :-) Nonetheless, cleaned it up, mixed some more and then got on with it. Job done, and hopefully I'll be able to rivet these suckers onto the rear spar in a couple of days.
