Brief Description: Deburr and wing skin / drill tank Z-brackets
Deburred all the holes on the top outboard wing skin. Organized the K1000-3 nutplates, AN3-4A bolts and AN960-10L washers for the fuel tank Z-brackets in between times to give my shoulder a break. Rounded the corners of the wing skin and also the fuel tank skin. Then decided to drill the fuel tank Z-brackets for the nutplates using my Avery jig and finally countersunk the rivet holes for the AN426 rivets so the brackets will sit flush against the main spar when assembled. Called it quits for the night. Tomorrow we need to edge finish the wing and fuel tank skins, dimple the wing skin and then we're ready to prime on Sunday if the weather plays ball and I'm not skydiving...
