Fabricated the remaining stiffeners for one side of the rudder. Jackie marked and I cut, and then I cleaned up on the scotchbrite wheel and Jackie then did the emery cloth thang while I match drilled and cleco'd onto the skin. Handy having some help. The time logged reflects 'man-hours' rather than actual time spent (I will always log man-hours when I have an assistant as I believe it is a truer indication of how much time it actually takes to build).
