Riveted the lower surface of the two end ribs to the skin, and the lower l/h side skin to the rear spar. Riveted the end ribs to the rear spar. Blind riveted the HS-708 main ribs to the rear spar. Had to stop at that point to go and collect Jackie from the airport which is a couple of hours drive away.
