Jeff & Jackie's RV-8 Project
Date:  11-3-2005
Number of Hours:  1.75
Manual Reference:  6-4
Brief Description:  Riveting on horizontal stabilizer
Riveted the HS-707 nose rib to the HS-801PP horizontal stabilizer skins (top & bottom for both skins). Riveted the HS-706 tip rib to the HS-702 front spar. Blind riveted the HS-707 nose rib, HS-702 front spar and HS-708 main rib. Riveted the top surface only HS-801PP skin to the HS-702 front spar and HS-708 main rib of the left-hand side of the horizontal stabilizer. I'm feeling happier now about riveting alone; just requires a little planning. Primer hasn't flaked off of this skin around the rivet holes like on some of the holes on the outside of the vertical stabilizer, so I obviously did a better job first time round! Might not get much done tomorrow; I need to clean house before Jackie gets home!!
