Tonight I fitted an AMP Series 2 CPC (circular plastic connector) plug 17-28 (part# 205839-3) to the rear Infinity stick grip wiring. Socket contacts (part# 1-66504-0) are crimped to each wire which are then inserted into the plug. The pin contacts will be fitted to the square bodied receptacle which will be mounted to a bracket riveted to one of the ribs under the floor. A flexible cable boot (part# 207241-1) supports the cable.
Here is a list of the parts I ordered from www.mouser.com for the rear stick connector as shown:-
571-2058393, Plug, qty 1
571-2072411, Flexible cable boot, qty 2
571-1665040, Socket contact 24-20awg gold flash over nickel, qty 16
